Vango Galli III RSV Low Drive Away Air Awning
£1,099.00 Inc VAT
Out of stock
Email Me When Back in StockNote: This is the Right Hand Side Low version which is designed to connect to the sliding door opening on the right side of the vehicle ie: Drivers side of a Right hand drive with a height of 180-210cm if in doubt please contact us before ordering.
Ideal for European vehicles such as VW Californias, Mercedes Marco Polos and vehicles with Twin Sliding Doors. Please note : This awning can be fitted the left hand side of the vehicle but the main entrance will be located toward the rear of the vehicle. This may be of preference to people owning campervans with rear conversions.
The Galli III has been updated with new skylight windows, allowing stargazing at night and a bright living area during the day. On top of this, the new AirZone system enhances the circulation of air within the awning, reducing the chances of condensation. There is even the option to add in one or two inner bedrooms to offer dedicated sleeping space at the rear, ideal for large families or groups of friends. Flexibility is key in a drive away inflatable awning and to enhance this, we have included 2 side doors in the connecting section between the awning and your vehicle, creating a great utility room for storage that will help your space stay clean and dry. The Galli III brings a fresh approach to drive away awnings
- Vango AirAway Structure – Inflatable AirBeam technology allows for pole free pitching and easy erection on your vehicle (double action pump included)
- Sentinel Pro 420 Fabric – Featuring 420 denier double ripstop threads, our Sentinel Pro fabric has superior strength and long-lasting durability
- Oxford polyester groundsheet
- Fully Sewn-in Groundsheet – Groundsheet is attached to the flysheet with an external storm skirt
- AirSpeed valve system and easy access positioning
- Pre-angled beams – Achieve greater internal space than with a standard curve.
- SuperBeams – Larger diameter beams providing additional structure and stability to the awning
- Patented Vango TBS II Tension Band System – Ensures awning performs in adverse conditions, especially in strong, changeable winds
- Pre-attached 6mm Kador strip – The most common and easy to use connection system for awning attachment to vehicles
- Touch fastener roof bar attachment tabs – Simply wrap around vehicle roof bars for quick and easy use
- Pole & Clamp kit sleeve – Allows optional pole & clamp kit attachment, for vehicles without a kador rail yet obtain a gutter
- 8m Straps included – Straps can be tensioned and rested over the vehicle, allowing the awning to attach to vehicles without kador rails
- Webbing storm straps – Provides secure guying at the front and rear of the awning
- Line-Lok guyline runners – Lock securely, simple to release and high performance in all conditions
- Reflective webbing – Picks up torchlight so the pegging points are easily spotted in low light conditions
- Large Diamond clear windows – Provide bright and airy environment
- Zipped privacy curtains
- Mesh Side Windows with PVC Covers – Improves ventilation
- Roll away rear porch – Can be rolled away when not in use
- Vango AirZone – Ventilation panels create a comfortable flow of air through the awning which significantly reduces condensation
- Fully taped seams – All flysheet and groundsheet seams are factory taped which provides a watertight seal
- Wide mouthed bag with compression straps – Allows your awning to be packed away and carried to and from the campsite easily
- Steel rock pegs and mallet included
- AirBeam Pump Included with a pressure dial
- Cable entry point with tidies – Zipped entry point for power cable, with touch fastener tidies
- Lantern Hanging Points
- Fire retardant fabrics
- Fully wind and rain tested
- External doors in connecting panel – 2 external doors at each side of connecting panel for convenient access to and from your awning
- Ventilation system – Larger vents increases air flow
- SkyTrack II – A flexible hanging system which allows you to easily attach lighting, storage etc
- Orange reflective guylines with tidies
- Skylight Windows – Windows which run along the roof line of the awning to enhance light during the day and for star gazing at night
- Over vehicle webbing straps – Can be tensioned and rested over the vehicle, allowing the awning to attach to vehicles without kador rails
- Vehicle height: 180-210cm
Specifications
- Weight: 28.95
- Awning Size: Low
- Floor size: 320 x 465cm
- Packsize: L78.0 x H39.0 x W44.0cm
- Kador Adjustable Height: 180-210cm
- Kador Length: 250
- Weight without Accessories: 23.5kg
- Pitching Time: 15 mins
Weight | 30 kg |
Dimensions | 78 × 44 × 39 cm |
