VW California
Caravan
Drive-Away Awnings
Tents
Vango Galli III TALL Air Drive Away Air Awning
£1,149.99 Inc VAT
Out of stock
Email Me When Back in Stock
The Vango Galli AirAway Awning is ideal for anyone who wants a larger and more usable space on their outdoor holiday. The inflatable AirBeam technology means you can pitch this awning in a matter of minutes so you’ve got more time to enjoy your holiday. The pre-angled beams mean there’s ample height throughout, and the option to add up to two inner tents means there’s great potential to create extra sleeping space.
  • Vango AirBeam® – Quick to pitch and creates a strong and rigid structure
  • Side Attachment – Awning attaches to your van with a side attachment to ensure you are always facing the view wherever you go
  • Sentinel Pro – Designed for dedicated motor homers and caravanners who embark on several trips a year. Sentinel Pro is created by a blend of fibres and double ripstop construction, making it extremely waterproof and durable. Not to mention its new ColourLok™ technology to enhance resistance to UV fading.
  • Oxford Polyester Groundsheet – The perfect balance between low weight and high durability
  • Fully Sewn-in Groundsheet – Groundsheet is attached to the flysheet with an external storm skirt to provide a bug and draught free environment
  • SuperBeams™ – Larger diameter beams providing additional structure and stability to the awning
  • AirSpeed® Valve System and easy access positioning – Designed by Vango to inflate your AirBeam®s with even less effort
  • Pre-angled Beams – Achieve greater internal space than with a standard curve. Provides effective bracing against winds
  • Vango Patented TBS®II Tension Band System – Ensures awning performs in adverse conditions, especially in strong, changeable winds. When tensioned, the bands brace the beam or pole at 3 points and prevent sideways movement. Adjust TBS®II to remove slack. Do not over tension, as this may deform the poles. Can be stowed away in calm weather
  • SkyTrack II® System – A flexible hanging system which allows you to easily attach lighting, storage or SkyLiners
  • High Visibility Guylines with Tidies – High visibility lower half to prevent tripping hazards and ensure stability in high winds, with touch fasteners tidies to roll up the guylines when not in use
  • Adjustable Pegging System – Allows awning to be pitched perfectly on uneven surfaces
  • Diamond Clear Windows – Maximise light and visibility to provide a bright and airy environment
  • Skylight windows – Windows which run along the roof line of the awning to enhance light during the day and for star gazing at night
  • Zipped Privacy Curtains – Simple and quick to use, allowing varying levels of opening. Fitted to the flysheet with no gaps that simply rolls down into a pocket
  • Covered Entry – Gives a sheltered entrance into your awning, which prevents rain from dripping into the living area
  • Two Doors in Tunnel – For convenient access to the front or back of your vehicle
  • Roll Away Connecting Tunnel – Quick and easy when you drive away for the day, simply roll back the tunnel
  • Flat Side Entry Groundsheet – Allows entering the awning effortless
  • 2 Mesh Doors – Front and side doors fitted with internal mesh panel for bug free ventilation
  • AirZone Ventilation – High and low level ventilation panels combine to create a comfortable flow of air throughout the awning, which is essential for reducing condensation
  • Oversized Bag – The wide opening makes it simpler to pack away your awning. This design also includes robust compression straps allowing you to reduce the overall pack size
  • Supplied with Double Action Pump – Rapidly inflate your awning (comes complete with a pressure dial)
  • Supplied with Steel Ground Pegs and Mallet – Strong, durable and can be used on more challenging terrain
  • Multiple Attachment Methods – Pre-attached 6mm kador, over vehicle straps, roof bar attachment tabs and sleeve for pole & clamp
  • AirAway® Vehicle Awnings included with – Pre-attached 6mm kador strip, over vehicle webbing straps, roof bar attachment tabs, sleeve for pole & clamp, steel rock pegs & mallet with carry bag, easy pack carry bag and double action pump with carry bag
  • Storm Straps – Additional stability for your awning in strong winds. Simply clip onto the pre-attached buckles and peg into the ground to secure
  • Cable entry point with tidies – Zipped entry point for power cable, with touch fastener tidies
Data
  • Weight: 28.95
  • Awning Size: Low
  • Floor size: 320 x 465cm
  • Packsize: L78.0 x H39.0 x W44.0cm
  • Kador Adjustable Height: 245-295cm
  • Kador Length: 250
  • Weight without Accessories: 23.5kg
  • Pitching Time: 15 mins
AWPGALLI C3YTDP
Weight 30 kg
Dimensions 78 × 44 × 39 cm
Vango
Be the first to review “Vango Galli III TALL Air Drive Away Air Awning”
You may also like…
  • Outdoor Revolution Movelite T4E Drive Away Air Awning Low
  • Kampa Dometic Touring AIR Low TC Drive Away Awning RH Version
  • Kampa Dometic Touring AIR Drive Away Awning (L/H Version)
£1,149.99 Inc VAT
Discount Code - SALE10
    SUBSCRIBE
