VW California
Caravan
Drive-Away Awnings
Tents
An excellent space to spend time with friends and family, the Vango Kela Air TC drive away awning inflates in a few minutes, leaving you with more time to enjoy your break. Designed to attach effortlessly to the side of your campervan, the Kela has 4 attachment options and the tunnel space creates the ideal storage area or corridor, so you can keep your awning and vehicle clean and dry. Created using Sentinel Signature fabric, perfect for keeping your awning cool in the warmer months while still being breathable and highly waterproof. Whatever your adventure, the Kela will be there at the end of the day.
  • Optional Carpet Available – Give your awning all the comforts of home without compromising your outdoor experience
  • Optional Groundsheet Protector Available – Protects built in groundsheet from rough ground. Prevents awning base getting wet and dirty, allowing easier pitching, packing and storage
  • Optional SkyLiner Available – Internal roof liner to help reduce the effects of condensation and provide a thermal barrier in cold weather. Connects to SkyTrack with pre-attached SkyHooks
  • This awning has multiple additions available for enhanced functionality – Please check our additions table for more details
  • Adjustable Pegging Points – Allows awning to be pitched perfectly on uneven surfaces
  • Tunnel Adjustment Strap – Helps collect any excess material and creates a neater looking tunnel and a tighter fit to the vehicle
  • Inflatable AirBeam® Structure – With 10 years’ experience in AirBeam® technology, we are the leaders in pole free pitching. AirBeam® technology ensures your awning is erect within a matter of minutes allowing you more time to enjoy your holiday (Supplied with double action pump)
  • AirSpeed® Valve System and Easy Access Positioning – Designed by Vango to inflate your AirBeam®s with even less effort
  • Cable Entry Point – Neatly feed electrical cables into your awning allowing you to easily keep your camping appliances powered
  • Diamond Pro Windows – 67% thicker than our Diamond Clear windows, they provide additional insulation and clearer views
  • Drive Away – Using the addition of a Drive Away Kit, detach the tunnel area of your awning from your vehicle and roll it away leaving your awning free standing as you explore for the day. Keep a note of your parking position for when you return and re-attach the awning to your vehicle
  • Line-Lok® Guyline Runners – The Line-Lok® tensioner locks guylines securely in tension, is easy to release and will give a high performance in all conditions
  • Pre-angled Beams – Achieve greater internal space than with a standard curve. Provides effective bracing against winds
  • Reflective Webbing – Picks up torchlight so the pegging points are easily spotted in low light conditions
  • Sentinel Signature Fabric – Combines the leading properties of both cotton and polyester to create a rich polycotton fabric which is breathable and easy to maintain. Sentinel Signature is a high-quality fabric that is luxurious to the touch, robust and durable
  • SkyTrack II® – A flexible hanging system which allows you to easily attach lighting, storage or SkyLiners. The SkyTrack system allows you to customise your awning to suit your needs. (SkyHooks included)
  • Steel Rock Pegs Included – Pegs are strong, durable and can be used on more challenging terrain. Supplied with a handy carry bag
  • TBS®II Tension Band System – Ensures awning performs in adverse conditions, especially in strong, changeable winds. When tensioned, the bands brace the beam or pole at 3 points and prevent sideways movement. Adjust TBS®II to remove slack. Do not over tension, as this may deform the poles. Can be stowed away in calm weather
  • Touring Awning – This awning is designed for touring use; it is not designed for static or long-term seasonal pitching as extensive exposure to UV light will cause accelerated fabric degradation. UV degradation is not covered under the warranty. However, under normal holiday use your awning will give long service
  • Zipped Privacy Curtains – Simple and quick to use, zip curtains allow varying levels of opening or simply roll down and secure away
  • AirBeam® Pump Included – Double action pump that will rapidly inflate your AirBeam® Awning which comes complete with a pressure dial and handy carry bag
  • AirZone Ventilation – High and low level ventilation panels combine to create a comfortable flow of air throughout the awning, which is essential for reducing condensation
  • Bracer Beams Included – Small AirBeams® secured in between main AirBeam® structure for enhanced stability
  • Great for Continental Use – Breathable fabric helps to regulate temperature inside your awning
  • Easypack Carry Bag – Oversized carry bag to make it easier to pack the awning away
  • Fully Wind & Rain Tested – Tested with wind and heavy rainfall to the European standard EN5912
  • High Visibility Guylines – High visibility lower half to prevent tripping hazards and ensure stability in high winds
  • King Pole Door – Door can be used as a canopy by adding additional king poles through the door eyelets, providing shelter from sun or rain
  • Multiple Vehicle Attachment Methods – All our awnings come with pre-attached 6mm kador, 8M over vehicle straps, roof bar attachment tabs and sleeve for pole & clamp kit system. This ensures our awnings are compatible with any vehicle
  • Roll Away Connecting Tunnel – Detach your awning when you drive away for the day, simply roll back the tunnel and toggle it to secure
  • Secondary Mesh Doors – Fitted with internal mesh fly screen for bug-free ventilation
  • Fully Sewn-in Groundsheet – Groundsheet is attached to the flysheet with an external storm skirt to provide a bug and draught free environment
  • Skylight Windows – Windows which run along the roof line of the awning to enhance light during the day and for star gazing at night
  • Supplied with Pack of 10 Skyhooks – Simply slide on to the SkyTrack® System to hang storage or lights
  • Two Doors in Tunnel Attachment to Vehicle – For convenient access to the front or back of your vehicle
Specifications
  • Weight: 22.4kg
  • Packsize: L78.0 x H38.0 x W41.0cm
  • Awning Size: Low
  • Kador Adjustable Height: 180-210cm
  • Kador Length: 248
  • Weight without Accessories: 17.4kg
AWRKELATCC3YTDR
Weight 20 kg
Dimensions 78 × 34 × 32 cm
Vango
Be the first to review “Vango Kela Air TC Low Drive Away Awning”
You may also like…
  • Vango Drive Away Awning Kit 6mm to 6mm (3m Length)
£1,199.99 Inc VAT
