Vango Shadow Grey Radiate Double Sleeping Bag
£133.95 Inc VAT
Only 1 left in stock
Found this item cheaper?The innovative Vango Radiate Double sleeping bag is new for 2021 and is sure to keep you warm when sleeping under the stars. Not only is this a deluxe 3-season, 10 tog sleeping bag, it also features two built-in Graphene heating elements, allowing you to top up the heat in your sleeping bag when connected to a power source. With twin touch button controllers, this bag offers the perfect solution for those who want that extra warmth. Compatible with any power bank, the Radiate sleeping bag will add a touch of luxury to your camping kit, with its high-quality fabrics and fills and integrated head rest. Ideal for use in spring through to autumn.
- Grade A Quality Fill – Superior fibre fill which is designed to be durable, warm and lightweight, while retaining its loft and soft touch
- Independently Tested – Gives you reassurance that the temperature ratings are accurate ISO 23537-1:2016
- Hanging Loops – Allows you to easily hang your bag for quick and easy drying
- Integrated Headrest – Provides extra comfort and warmth for your head
- Square Shaped Sleeping Bag – Provides extra space to have greater freedom of movement when sleeping
- Auto-Lock Two-Way Zip – Seals in warmth and provides adjustable ventilation. Auto-lock prevents the bag from opening during the night and can be accessed from inside the bag
- Polair® Snug Lining – A super soft and cosy brushed Polair® polyester fabric that offers a warm handle. Ideal for snuggling into at night (190T)
- ThermoLock Pro Insulation – Increased durability, extra warmth and retains loft in damp conditions
- Woven Zip Puller – Allows you to quickly and easily move the zip
- Zip Guard – Helps prevent the zip from snagging on the lining, allowing easy opening and closing
- Insulated Zip Baffle – Retains heat within the sleeping bag and reduces cold spots
- Polair® Micro Shell – A soft to touch microfibre fabric that is wonderfully cosy, snug and breathable (210T)
- Offset Double Layer Construction – Counteract seams prevent cold spots at the stitching lines
- Compression Carry Bag – Reduces pack size for easy transportation
- Hexagon Stitching – Holds the insulating fibre in place for an even distribution across the body, providing warmth and comfort
- Square Shape Carry Bag – Allows for quick and easy packing
- Power Bank Compatible – Works with many power banks – best suited for power banks with an output of 5V/2.1A
- Washable – Can be machine washed up to 30 degrees
- Two Flexible Electric Component – Two pliable electric components which works with your body
- Two Touch Button Controllers with 4 heat settings at the touch of a button. One controller for each side of the sleeping bag, lets you top up your heat individually
- Two Graphene Heat Elements – Using the most innovative materials, the heating panels are constructed from Graphene
- Two Pockets – Situated on each side of the sleeping bag for storing the power bank
- Convert into 2 Single Bags – Unzip the bag and use as 2 singles for ultimate flexibility. One bag will have both the Graphene heat panels meaning it will be super warm. The other bag will be the standard equivalent without the technology.
- Built-in Heat – Heating element built into the product to give you variable heat when connected to a power source
SBRRADIATS32S68
