Vango Tailgate Hub Low Drive Away Awning Poled
£399.00 Inc VAT
Out of stock
Email Me When Back in StockThe Tailgate Hub is Vango’s first rear attachment awning, ideal for couples or independent travellers with a spirit of adventure. The perfect quick pitch for short stops, the Tailgate Hub has been designed with active adventurers in mind. Effortless attachment requires only pegging straps at the front of the vehicle and tunnel area, allowing the awning to fit neatly to your vehicle without the need for kador rails. However, should you wish to use them, the traditional attachment options of roof bar attachment tabs, kador and a sleeve for pole and clamp are also included. Two doors in the connecting tunnel make for a convenient storage area, while Vango’s reliable and lightweight Sentinel Active Fabric, ensures a compact pack size, easily stored away when not in use. The Tailgate Hub does not require the tailgate to be open to support the structure, so you can simply roll away the connecting tunnel should you want to drive off and explore for the day. Be ready for any adventure with the Tailgate Hub.
- Touring Awning – This awning is designed for touring use; it is not designed for static or long-term seasonal pitching as extensive exposure to UV light will cause accelerated fabric degradation. UV degradation is not covered under the warranty. However, under normal holiday use your awning will give long service
- Easy Access Doors – A flat entry access door creates easy access for wheelchairs, prams and people with reduced mobility
- This awning has multiple additions available for enhanced functionality – Please check our additions table for more details
- Optional Groundsheet Protector Available – Protects built in groundsheet from rough ground. Prevents awning base getting wet and dirty, allowing easier pitching, packing and storage
- Mesh Front Door – Fitted with internal mesh fly screen for bug-free ventilation
- Diamond Clear Windows – Maximise light and visibility to provide a bright and airy environment
- Toggled Privacy Curtains – Easy to use privacy curtains that can be simply rolled away when not in use
- Lantern Hanging Points – Conveniently positioned to attach your light(s) with ease
- Supplied with Steel Pegs – Strong and durable pegs ideal for grass pitches. Supplied with a handy carry bag
- Easypack Carry Bag – Oversized carry bag to make it easier to pack the awning away
- Vango PowerFlex® Fibreglass Poles – Creates a strong, yet light and reliable structure
- Sentinel Active Fabric – When pack size and weight are the key influencers in choosing your awning, our specifically designed Sentinel Active fabric will surpass your needs. Sentinel Active is strong, whilst being fully waterproof, ensuring great quality and performance coupled with compact pack sizes
- Experience Poled Awnings included with – Pre-attached 6mm kador strip, over vehicle webbing straps, roof bar attachment tabs, sleeve for pole & clamp, steel pegs with carry bag and carry bag with compression straps
- Optional Carpet Available – Give your awning all the comforts of home without compromising your outdoor experience
- Tunnel Adjustment Strap – Helps collect any excess material and creates a neater looking tunnel and a tighter fit to the vehicle
- Roll Away Connecting Tunnel – Detach your awning when you drive away for the day, simply roll back the tunnel and toggle it to secure
- Two Doors in Tunnel Attachment to Vehicle – For convenient access to the front or back of your vehicle
Specifications
- Weight: 11.0kg
- Packsize: 75 x H27.0 x W27.0cm
- Pitching: Time:8 mins
- Awning Size: Low
- Kador Adjustable Height: 180-210cm
- Kador Length: 220cm
- Weight without Accessories: 6kg
AWRTAILGAS0YTDR
