Sale!
Water Tank Filler 40mm Complete with Cap
£14.95 Inc VAT
Only 2 left in stock
Found this item cheaper?
The Water Tank Filler Cap 40mm – Black, is a water inlet with a lockable cap. The filler inlet and pipe neck diameter measures 40mm and the cap comes complete with two keys. The lockable filler cap is ideal to use to avoid contamination of your fresh water supply. Suitable for replacing lost or damaged compatible water filler housings, ideal for use on motorhomes, caravans and van conversions. The outer housing of the filler cap measures approximately 120mm and comes in black, it has three pre cut holes ready for fitting (screws not included).
- Lockable cap
- Two keys included
- Suitable for compatible caravan, van conversions and motorhomes
- Ideal replacement for lost or damaged caps
- Use to avoid water contamination
- 40mm inlet pipe neck diameter
ES2100
Weight | .300 kg |
Dimensions | 18 × 13 × 14 cm |
