My local van centre says the approved VW aftermarket are incompatible with a 4Motion. Anybody else used any alternatives or been told different, which seems unlikley.
Do you have heavy duty anti roll bars fitted? They seem to help reduce roll in corners, even with standard springs. Available as a retrofit I believe.In comparison to the 9 year old T5 T32 conversion it has replaced it wallows on corners a suprising amount.
It’s almost as if they were designed and named with that exact purpose in mind....Do you have heavy duty anti roll bars fitted? They seem to help reduce roll in corners, even with standard springs. Available as a retrofit I believe.
