Laercio
Yes, the rear socket comes from the board battery and is permanent live. I know because I use this to power my water pump!
Lithium should be easy for you under the bonnet if the temperature isn’t going to drop below Zero. If you use a certified electrician I don’t think it will effect your warranty as I think I’ve read on German forums that it’s okay.
I’ve heard there’s great wild camping in Portugal - let’s hear about your travels!
Thank you Bruce!
I’m thinking to do my setup using what I already have from this socket, unfortunately change the board battery under bonnet will void the warranty they told me “VW used this setup for a reason”
The sad part is that the ones with solar like ours is already completely equipped and ready for Lithium, is just a drop in replacement it have the DC to DC converter and have the option to change the solar and DC control to Lithium, I took the measurements and a Relion Lithium 300ah fits under the bonnet there perfectly and have almost the same weight of the 92ah agm! I don’t know what happens with all that heat though
Let’s see what happens in the near future, I will ask a different dealer and will keep doing my research, I’m a digital nomad and I consume a high amount of power to do my work and would like to have a setup to be independent around a week so I can go to paid camping site only once a week
Is true here in Portugal is easy to park and sleep pretty much everywhere if we follow the rules, you are welcome here Take care!
