nknight
Help please. Our 2009 174 Cali which we've had from new has had a problem with the manual aircon for the last two plus years. It normally but not always works for a while after you switch on the engine but then then stops. There is no fixed time for how long it works. It can be 10 or as short as 5 mins other times it can be longer like today it was the whole 1 hr 30 mins journey. Sometimes it won,t work at all. If it stops working and you stop the engine then restarting the engine will often cause it to work again. Other times after the aircon stops working it doesn''t work until the engine is started the next day. The switch light continues to show the aircon is on even when it stops working and if you turn the switch off when the aircon is working it won't work again when you press it to on even though the switch light is on. Our local VW van van dealer has tried unsuccessfully to identify and rectify the issue over the relevant period including re-gassing the system many times checking for leaks. They originally didn't believe there was a fault and just re-gassed it. Eventually they did recognise there was a fault but sent it back working only for it to stop working 5 minutes from the garage. At one point they replaced some wiring after getting a wrong voltage reading and that improved things for a while but eventually we were back to square one. Dealing with them has become immensely frustrating as often it seems they have no record of what they did before or system for tracing this kind of fault Does anyone have any ideas?
