Any one having "b104c29 Key - Range/Performance" errors (not key battery related for sure)? Clues to solve?
PoyntonBlue
PoyntonBlue
South Manchester
T5 SE 140
Hi all, I have an intermittent "b104c29 Key - Range/Performance" code coming up on a diag, and it does occasionally end in a "key not found" error, which after one or two attempts goes away & the Cali starts. Its NOT the key battery for sure. Any thoughts? T5 2014 with no mods other than the 'accidental aero restyle' my partner has given to three of its corners.
Do you have another key ?
If so switch keys to see if the problem persists.
Then at least you'll know if it's the key or the van
