jts46
Does the Fiamma one fit the VW awning ?
yes with the correct brackets. I have one on my cali
I have the std VW awning , so am after the rafter to fit to it.When you buy the new awning you need to buy the fixing brackets. Or are you talking about the fiamma rafter?
Not sure what it it, just the standard one on a new T6 Oceanjust looked on the omnistor web site they sell them. IF it is an omnistor?
One leg shorter than the other works fine, but it needs to be a significant difference. The puddle builds up quickly if you forget to do the legs before it starts to rain. I did forget last month and got half a gallon of cold water down my collar!We have recently bought an Awning kit via Nick at Comfortz Leisure - it has enhanced the enjoyment and capabilities of the van massively. Up to now we have been lucky and only used the kit in good dry weather. Off to the Lakes later this week and predictably the forecast is for heavy rain at some point. I understand it is good practice to have one support leg lower than the other to allow rain to drain off the Awning - any other advise as I am unsure of the Awnings limitations.
I note what your saying but if that is the case why do the manufacturers sell so many accessories such as sides, tie down kits and extra roof struts. Obviously it is not for use in storm force winds and rain but should be able to cope with normal weather variations.The awning correct name is sun canopy, it is not designed to be used it rain
