Hi,
We have the calibed roof III. It is definitely an improvement over the included mattress. The only thing I found is that when you roll over you could feel the slats below (but not when laid in one position) to rectify this I bought a couple of foam mats. Now they are underneath the bed is so comfortable and you can still keep the mats and mattress in situ when you lower the roof
Hi - I noticed that the Calibed Rood III is listed as a 6.1 option. What van do you have? I'm looking for a mattress for our T6 and was hoping that this would fit.
The only issue I had was that it seems to pop the offside back corner of the roof up by about a cm. Has anybody else had this? I made some adjustments to the roof scissors and have balanced the roof again - take a look at this thread here if anyone needs to know how to do this: https://vwcaliforniaclub.com/threads/adjusting-rear-roof-scissor.37190/
Hi - yes we already had the "footer" mattress from the original set-up and have kept that. It's about 4cm thick versus the 6cm or so for the Calibed II but seems to fit OK and we've never had to remove it to close the roofGlad you like the Calibed. I think my roof still closes just fine, but it is good to know that the closing can actually be adjusted, thanks!
Is this using just the main Calibed Roof II mattress, or did you also get the separate small mattress part for the foot end of the bed? That one ’officially’ has to be taken down when closing the roof I remember. Just wondering if you made it fit somehow.
