P
Paul S
- Messages
- 189
Intrigued by this on the options list. What does it actually do? I assume it is some form of air cleaning thingy. Is it worth having and can it easily be retrofitted?
Thanks Loz,I would guess that it goes in place of the pollen filter in the heater box.
Did you ever find yours?Thanks Loz,
You may be right. In my ignorance I've been assuming that it's an additional item on top of the usual pollen filter. I had a quick poke around earlier today but couldn't see anything that looked remotely like a "canister". I am sure it will get replaced when it goes in for it's first full service. It's just that I've noticed it's included amongst the vehicles specification codes in the service book and I am curious as to where it's located.
No, never did find it. Apparently our new van has got one so I must as the service bods when it next goes in.Did you ever find yours?
Checking my "options" suggests that mine had a charcoal canister fitted when new but I can't see anything apart from the normal paper filter in the passenger footwell.
Thanks, I think that explains. Its just a alternative to the paper type, rather than a separate "canister".I have an older Calli (2006). The air filter for the passenger compartment comes in paper type or coal type. I always replace this my self. I use the coal type which is little bit more expensive. If you go to a work shop they always use the paper type. In addition to that I always clean the ventilation system to (with CRC Airco Kleen), which ones again workshop does not.
Many cars have also a charcoal canister connected to the breather pipe to the fuel tank. I guess that’s for protecting the environment...
