t6.1
Hi all, this child safety net clip broke. Does anyone know where I can get a replacement please? (or something else that would do the job?)
It is indeed! But it doesn’t look like you can actually buy them from there unfortunately.
Thanks, that’s a great idea, just need to make sure the hole is the correct size. I’ll look into it, cheers!Personally I would try with this. Certainly stronger and cheaper. All the former tent campers have at home.
Wow ! Thanks for the infoMain dealer was the only place I could get one, they are about £8 to buy and £30 fitted. (I bought one about 18months ago, that was the prices then)
Are they not supposed to sit flat when the roof is dropped so they don't dig into the bed or stress the alloy roof, hence the plastic hinged design?Back again!
I did as @ThomasHJ recommended and drilled out the hole on some Tent Rope Fasteners, the inner hole was a bit sharp but did the job and certainly more robust.
We had the van serviced and I'd mentioned the clips so got them replaced with the official ones, but they've broken again
Wondering if anyone else has replaced these? and what you've used?
I just remembered about Meccano, going to give these a try :
Meccano 20 Standard Obtuse Angle Bracket 12c
