I did a lot of research on this as our Cali is black and if you don't do it correctly it will look awful.
I use a two bucket system. One to wash and the other to regularly rinse the mitt.
Before washing it for the first time I bought the following:
1. An alluminiun step platform to stand on when washing the roof etc.
2. 2 x Large buckets with grit guards.
3. A marino lambs wool wash mitt.
4. Autoglym wash liquid.
5. A stack of micro fibre cloths.
6. Some pre wash foam for the jet washer.
( I already had a jet washer )
I know it sounds a lot of stuff but you can't just use a yard broom on black paint as it shows every mark.
When I wash it (and that is not every week) I do it as follows:
a. Wash it off thoroughly with the jet washer.
b. Apply the prewash foam with the jet washer and leave to work.
c. Wash that off with the jet washer.
d. Wash each panel with the Marino mitt using the two bucket system.
e. Wash off with the jet washer.
f. Pat dry with the micro fibre cloths.
The jury is out on the prewash stuff so steps b and c are optional.
The essential think is to wash the vehicle without introducing any grit to the wash.
Never wash on a hot sunny day. Much better results if you use a dull day or a light drizzle to wash in.
Good luck.
Fixed rate. I accept Belgium beer tokens.Can i make a appointment to clean mine , fix price or rate by the hour?
Hello Alison,I used to go through a similar routine to Borris when washing my black little sports car and estate car. Time consuming. 6 months ago I switched to ENJO (chemical free). All of a sudden both cars could be washed and spotless (no stray marks as no chemicals used) in no time at all. High pressure hose, clean with ENJO glove, rinse with high pressure hose, dry with ENJO drying cloth. There are also 'fibres' for alloys. Again, "simples". Leaving more time to plan for the van... Sadly that meant selling the sports car... I'm sure I won't miss it after March 1st
Hello Snowy55,Nooooooo don't use a squeegy. Any grit will scratch.
Otherwise follow the instructions from Borris
Thanks Alison.Borris, I sent a PM with more info in case anyone thinks I'm advertising. Although I'm not a rep in any way shape or form. Just a convinced happy customer. Alison
Hello Snowy55,
I am wondering if I have described the item correctly. This is what I described as a the squeegy. Are we talking about the same thing? If we are, I would be interested in your experience of using them. If there is any likely hood of causing damage then I will be giving it the elbow.
I didn't get a free mug!
Hello Raggedroy,Hello again BlueBottle,
I forgot to mention these. They are briliant for getting the wheels thoroughly clean. Oh and an Autoglym squeegy blade thing that you can use to woosh the surplus water off prior to drying.
Hi Borris,Hello Raggedroy,
I noticed that you disagreed with my use of the merino wheel wands/woolies for cleaning alloy wheels. That's fine but can I ask why? I am doing something wrong or might I cause damage by using them? So far I have found them to be really good.
Is that like a snowfoam product, does it lift a lot of the dirt like people say?? ThanksThe jury is out on the prewash stuff s
Thanks Raggedroy,Hi Borris,
in my opinion your washing regime is spot on, its the squeegee I disagree with. As you mentioned black shows every mark. I follow a similar routine but use rain water for the final rinse to reduce water marks. I do use a squeegee but only on the windows.
Yes it is Snow foam. It does seem to shift most of the dirt left over after I've jet washed it. All that remains is a very thin film of hazy dirt. If you run your finger across the paintwork you can clearly see that it is still dirty.Is that like a snowfoam product, does it lift a lot of the dirt like people say?? Thanks
Thanks, I keep dithering over buying a lance and snowfoam, I'll probably succumb in the end.Yes it is Snow foam. It does seem to shift most of the dirt left over after I've jet washed it. All that remains is a very thin film of hazy dirt. If you run your finger across the paintwork you can clearly see that it is still dirty.
