Cooking assistance in Beach
Grey one
Grey one
West Sussex
T6 Beach 150
Fellow campers, assistance required for first time away in new Beach. I have resisted purchasing a cooker and kettle before the arrival of the vehicle but having now picked it up I am keen to try my first night in it. It's winter and want to cook inside. Going to New Forest in Hampshire, no hook up. I have seen references on the forum to gas, electric, microwaves etc and there are many options.
In short, what type of cooker would you use to boil water, cook rice or pasta and reheat pre cooked meals for two people inside the vehicle. Two burners or one? Does own boiled water naked good tea or is a kettle required. Where do you place a burning gas cooker, on the floor? Any models recommended?
By the summer I will have sorted the routine out but in the meantime, any winter advice?
Own boiled = pan boiled.
I have two stoves for inside the van but to be honest I've only ever used one.
A camping gaz bistro which uses those aerosol style cans. Although I have to say amazon is a rip off right now, I paid £6.50 for mine in Tesco during a sale at the end of the season. This is the only stove I've ever used inside the van to boil the kettle its surprisingly good and fast to heat up so I've never tried anything else. I used it on the table but iwth the roof up (down I suspect it may be a bit close).
I also have a alcohol based dual burner similar to a Dometic Origo but far cheaper, that runs from alcohol gel. Its odorless and cheaper to put fuel in. Is it as hot? I've not used it in anger but I expect not. IN theory the alcohol is better too because if it leaks it will just evaporate over time. Again not had to find out.
Keeping it simple looks the way to go.
We have one of these in our Beach. It's a Campingaz Super Carena single gas burner. It is very well made, takes up very little space and knocks out alot of heat. We use ours with a Campingaz 906 cylinder or is it a 907? can't remember. Well it's like the one in the picture.
If we need any more than one burner, we go down the pub.
Happy camping.
Happy camping.
There's a theme of keeping it simple coming through, thanks.
Another vote for the cartridge /aerosol units. Cheap, stable, cartridges available much more widely that the bottles and Fast! Gas in cartridges is fairly cheap if bought well. (£1 each). They do double burner versions, but they are a bonkers idea. Just buy two singles.
We have one of these double burners and grill for tent camping:
bl_173483_a
We've attached a propane regulator and use 5 Kg patio gas cylinders:
We intend to try using this set up in our Beach once it arrives, but intend to cook outside or in the awning, not in the van.
A double burner extends cooking options. Pasta on one burner, sauce heating up on the other.
bl_173483_a
Thanks. I can see the cooking outside/awning potential here. Looking at previous posts, without an externnal hook up, I can't see a better internal option than a single burner. Hope yours arrives soon.
Agreed. For Xmas I bought the Mrs 28 bottles of butane from Amazon for around £25. Should keep the old Bialetti going for a while.
Pan or kettle doesn't matter, but you must get a tea pot. You can't make a decent drink from a bag dipped in a cup.
Absolutely right you have to put the cup and bag in the microwave for three minutes......Proper tea not mamby pamby warm the pot stuff.
Aaaaaah, the horror, the horror!
My setup is:
  • JetBoil Sumo for making hot drinks
  • Cadac Safari HP for cooking (shares the same gas canisters as the JetBoil)
  • MSR Pocket Rocket stove as a backup (also uses the same gas canisters and is tiny)
The JetBoil and MSR are permanently in the van, while the Cadac just comes along for camping or BBQ days.
My setup is:
Jetboil is great kit.
We use one and a COBB for cooking dinners:thumb
My setup is:
Very helpful thank you.
I will definately consider the alpkit for shorter trips, I find it a small hassle to pack my small gas stove with all kit.
Alpkit Brewpot here too. Fraction of the price of the jetboil and just as good.
Alpkit brukit - best piece of kit in the van - quicker than the Kettle at home and being gas powered no electricity needed.
