Vantastic2
Many years ago starting before 2013 Cali's, Someone on here spotted corrosion on the front roof panel. There was also paint bubbling of the aluminium roof too.
Mine was one and the Cali's that had to go to a so called specialist nominated by VW. Was told VW was paying out over 4K for ever Cali to have the repair. After VW so called 'specialists' failed on first type of repair, they then fitted a polyurethane cap over the top of the panel, mine failed and lifted during heat after the one yr warranty ran out but again thanks to being with VWcaliforniaclub a member helped me finding an adhesive that he tried himself and worked which I did and no more panel uplift, no more water coming in.
So was wondering seeing new cali's local if VW sorted out that problem where they had steel making contact with aluminium causing a reaction to lift the paint off (starting with bubbling) and owners not knowing if they bought over 70K's worth of rubbish?
