blondebier
Hi all,
I've noticed something that might be nothing but I thought I'd post and see what other people's experiences are.
Our T6 coolant gauge takes a while to get up to 90'C. It's taking longer in the cold weather and that's to be expected.
What I've started noticing is that even after 10 miles it still might not be up to temperature. Some of my commute home is downhill and when I'm following something at 50mph it will often coast at very little above idle in D7.
Would you expect the coolant temperature to drop in this scenario? Mine does a bit.
If I use the steering wheel paddles and drop a few gears to get the engine revs up, the temp will increase.
Is the drop in temperature normal?
I'd half expect the coolant temperature to get 90'C after 10 miles and stay there. Even if the engine is just ticking over.
I'm also noticing it's a struggle to get the oil temp above 85'C even after 20 odd miles.
Perhaps I should turn the coasting feature off?
The only way I can get the oil hot is manual override with the paddles and hold the engine revs for a while. It's getting pretty tiresome when the speed limit is 50 and the DSG constantly wants me to be in D7!
Any thoughts?
Any thoughts?
