Defender90
is it just my t6.1 that has poor Dab reception ? Mine is almost unusable.
Sadly I have the same experience..is it just my t6.1 that has poor Dab reception ? Mine is almost unusable.
Could be a north south divide issue lolFine in ours, MY21 Coast
Ours is sometimes rubbish but I think it’s the signal rather than the Cali? When it’s bad I go into settings and change to FM.is it just my t6.1 that has poor Dab reception ? Mine is almost unusable.
It may well be where you live. I regularly travel the northern part of the M6, and the A66, a lot of stations are unavailable in those areas. DAB radio is broadcast in multiplexes some are better than others, BBC stations are near universal around the country. DAB doesn’t seem to like high pressure weather systems either.is it just my t6.1 that has poor Dab reception ? Mine is almost unusable.
Do you have any 12v USB plugs being used. Some cheap ones notorious for causing DAB disruption.is it just my t6.1 that has poor Dab reception ? Mine is almost unusable.
Hi no we don't have any 12v usb plugs,the cali is defo worse than the t6.1 transporter i have as a courtesy car. Can any adjustments be made at the head unit?Do you have any 12v USB plugs being used. Some cheap ones notorious for causing DAB disruption.
Not to my knowledge apart from removing unit and checking the aerial plugs are fully connected.Hi no we don't have any 12v usb plugs,the cali is defo worse than the t6.1 transporter i have as a courtesy car. Can any adjustments be made at the head unit?
