bluerallye
Hi,
I have done a forum search on the above and found some useful info, however a couple of outstanding points that I couldn’t get to the bottom of:
1) I have about 15mm of lean, assume this can be dialled out but what am I looking at wrt turns? 1/2, 1, 2?
2) The lean is pretty consistent F/R, should dialling our on the front address the back or is it possible the rear springs have aged and would benefit from changing after dialling out the front?
3) I expect the dialling in can be done with weight on wheels (unjacked) or is it better to jack/dial/unjack and assess/repeat?
4) How many gallons of WD40 are recommended prior to attempting this
TIA
TIA
