ChocolateEclair
I'm contemplating DIY installing my own Westfalia detachable towbar to my 2015 T5.1 (the full kit is £238 from PF Jones with the 13 pin wiring kit as opposed to £580 fitted). My Cali has towbar prep. which from other posts I understand is behind the water filler but I have a couple of questions I'm hoping someone can help with:
1. How do you get the wiring prep. connector from behind the water filler to the towbar?
2. Does the wiring kit just plug in and work or does it have to be manually wired and then VCDS coded?
Thanks.
Thanks.
