Bridford
Selling at: £375
Location: Newton Abbot area not far from A38 if on your way to Devon or Cornwall
Great condition fridge used with care both inside and outside of van in driveaway awning.
The Dometic Waeco CFX28 CoolFreeze
The Dometic CoolFreeze CFX28 is a portable high-performing compressor fridge/freezer, with extra thick insulation while still being impressively quiet and efficient. Waecos CFX28 can withstand most of its demanding load due to its robust design while also being amazingly lightweight and easy to move around.
The CFX28 can change its temperature range from +10°C to -22°C (Please note that -18°C is the recommended minimum setting due to its energy efficient design) allowing fresh food, bottled drinks and frozen foods to stay fresh while stored.
Features:
Dimensions: 620 x 425 x 342 (D x H x W mm)
Net Weight: 13.1kg
Voltage: 12/24 V DC & 240 volts AC
Frequency 50/60 Hz
USB charging outlet.
Holds up to 28.2 Litres
Interior light
Features:
Net Weight: 13.1kg
Frequency 50/60 Hz
Interior light
