Accessories For Sale Dometic PLB 40 Compact Power Pack
Gillanschoice
Gillanschoice
Preston
T6 Ocean 150 4Motion
Dometic PLB40 Portable Lithium Battery, 40AH, Power Pack £500
Details & Specs
Travel off the grid for longer with your full kit by powering your 12V appliances with the lightweight and portable PLB40 Battery from Dometic.
This 40Ah Lithium Iron Phosphate battery is engineered to be used outdoors, so it has a rugged design that will perform even in extremely harsh conditions. It’s got a DC-DC charger and provides you with 3 ways to charge so through the vehicle 12V socket, solar panel or AC power. The integrated LCD display makes this battery easy to use as it provides you with important information on performance including the charging/discharging status, battery capacity and output status. You can even use it to charge mobile devices as there are USB ports on this unit.
The lightweight and ergonomic design will also make it easy to transport to and from the campsite. When you’re heading overland, the portable PLB40 Battery from Dometic will power your 12V appliances, mobile devices and portable fridge/freezers so you can travel further on your adventures.
Designed for use with 12V appliances while off-gridUSB ports for charging mobile devicesIntegrated Lithium Iron Phosphate LiFePO4 battery cellsLightweight with ergonomically designed stainless steel handle3 ways to charge - vehicle 12V socket, solar panel or AC powerIntegrated LCD screen displays charging status and output
In Use Dimensions:
19.7W x 19.7D x 25.7/29.5H cm
Packed Dimensions:
35W x 26D x 30.5H cm
Material:
Plastic | Rubber | Stainless Steel
Input Power:
12V DC | 10Amp ACDC charger | DC cable extension with Cig plug & Anderson connector
Output Power:
12V | DC Socket, 2−Pin Socket 15A | 2 x USB Ports (5V max, 4.2A overall)
Batteries:
Lithium Iron Phosphate (LiFePO4) | 12.8V, 40 Ah | Up to 2000 Charging Cycles | Lifecycle to 80%
Weight:
7.7 Kg | Charger & Cables 0.80 Kg
Ch1pbutty
Sorry Now Sold Sold
Ch1pbutty
Ch1pbutty
a892374923874
Californication69
Californication69
