![chris ratay traveler](/data/avatars/m/32/32314.jpg?1685986313)
Overlanding South America w T6.1 Ocean 204, 4M+
You mean apart from bump steer?Any issues with the ET35 offset?
The best place to check is - https://www.willtheyfit.com/Any issues with the ET35 offset? My 18x8 Palmerston rims are a ET50. Planning to run BFG K02 225/65r17.
Thanks for the link. The Palmerstons came with the van - 255/45r18 ET50The best place to check is - https://www.willtheyfit.com/
What tyre size do you run on the Palmerstons?
Yes, that is correct. That looks good. You will not be able to go lower than 17 as that will foul on the larger discs.Thanks for the link. The Palmerstons came with the van - 255/45r18 ET50
Looks like if anything, we'll have less chance of rubbing - right?
(I'm aware the tire I am considering will add 1.5")
