Drive away awning help
Brianc26
Brianc26
T5 SE 140
Hi
I've got a easy camp daytone, is there a slot in the standard wind out awning for the drive away awning to slip into ? Or will I need a figure of 8 loop and wedge it in the outside cover on the awning ?
Brianc26 - as HC as shown there are several threads on the forum on the subject. Depending what format you're viewing this in if you scroll down it will show you similar threads which may help. If this doesn't work and the search function doesn't help then pop back here with a specific question and someone will no doubt be able to help.
