Sorry Now Sold Driveaway Awning - Vango Kilda Airaway Low (same as Vango Palm Air Low)
  • Thread starter AlphaKiloSierra
  • Start date
AlphaKiloSierra
AlphaKiloSierra
Hampshire
T6 Ocean 199 4 motion
Vango Kilda Airaway Low (same as Vango Palm Air Low) for sale. Little used on our T6 California and in very good condition.
Includes storage bag and pump. Collection from Southampton. £150 or nearest offer. Dimensions are in the attached images. Full spec. after the attached images.
This is a drive-away version which is very handy for leaving this behind as you go off for the day etc. Very quick to set up. The air beams are so good to reinforce the structure and also makes this very resilient to strong winds. The groundsheet is separate and secures easily with toggles internally and does help keep the floor dry. The fitting to the van is very simple (just slides in).
Highlights:
Vango AirBeam® - Quick to pitch and creates a strong and rigid structure
Linked-in Groundsheet - Easy to clean groundsheet that can be attached or detached from the living area
AirSpeed® Valve System and easy access positioning - Designed by Vango to inflate your AirBeam®s with even less effort
Pre-angled Beams - Achieve greater internal space than with a standard curve. Provides effective bracing against winds
Bracer Pole included - Secured in between main poles to enhance stability
High Visibility Guylines - High visibility lower half to prevent tripping hazards and ensure stability in high winds
Adjustable Pegging System - Allows awning to be pitched perfectly on uneven surfaces
Diamond Clear Windows - Maximise light and visibility to provide a bright and airy environment
Toggled Privacy Curtains - Easy to use privacy curtains that can be simply rolled away when not in use
Two Doors in Tunnel - For convenient access to the front or back of your vehicle
Roll Away Connecting Tunnel - Quick and easy when you drive away for the day, simply roll back the tunnel
King pole doors - Integrated eyelets allow optional king poles to prop open doors, creating a canopy
Low Level Ventilation - Helps circulate air within the awning and reduces condensation
AirZone Ventilation - High and low level ventilation panels combine to create a comfortable flow of air throughout the awning, which is essential for reducing condensation
Mesh Front Door - Fitted with internal mesh panel for bug-free ventilation.
Lee damian
L
kellyscali
kellyscali
kellyscali
K
kevval
K
W
Whitewoods2022
W
