Cali-Dave
- Messages
- 15
- Vehicle
- T6 Ocean 204
Have just cleaned the roof drain, but how do you check that the pipe is connected?I recently had similar on the passengers side.
The roof drain pipe had come away from connector.
What’s the best way to clean the drain holes?Check your roof drains are clear
Some reading.Have just cleaned the roof drain, but how do you check that the pipe is connected?
I do not know. It was identified and fixed by VW van centre.Have just cleaned the roof drain, but how do you check that the pipe is connected?
Just out of warrantyIs it still under warranty?
When you say JUST out. Is it a month or a lot more? Sometimes good will can come into it if you’ve had you van serviced by the dealer.Just out of warranty
And also the headlining.This should help you.
Components 5, 12, 13 and 20 are the components for one of the front roof drains. There is an identical set up on the drivers side. To get at the joints (there are three on each side) you will have to remove some internal trim on your "A" post and possibly the access plate on the left side of the engine bay, immediately below the windscreen.
Hope this helps.
Just a thought is the headlling damaged by watermarks or stained?Thanks for your advice, will try out some of the tips tomorrow.
