Both stopped working at the same time... I think it has to be a fuse...Are you using the switch on the drivers door ?
Try using the passenger switch, it may be a failed switch, If the window on the passenger side works from the switch on the passenger side it’s the driver switch that’s bust. I had one go on a T5.1 no warning just stopped working. Very cheap and easy fix to replace the double switch.
pulled rubber boot...all clean inside...both windows shut down at same timeok I will pull the rubber
no key fob...You can check if the windows work by Pressing and hold the open button on the key fob, the windows should drop after about 5 seconds, you can then raise the windows by pressing and holding the lock button.
Certainly not.On a T4?
Not sure if the yellow (20A) is the right one. I would rather think its is 30A (green) or higher (40A, but that one I can't see here).I believe the window fuse is the yellow 4th in from right side of picView attachment 44370
thought not...Certainly not.
i tracked down a fuse box behind and above ...here was an electric window blown fuse...I just started to drive the 1996 Cali.. The drivers window and passenger windows have suddenly stopped in closed position. I can not think of anything that I have done to cause this...clean tracks, no jams etc...any suggestions
And does everything work again now?i tracked down a fuse box behind and above ...here was an electric window blown fuse...
