Anonymous
Guest User
Hi
New on here.
I have an 89 T25 Cali, 1.6 TD LHD hi top. Based in S. Manchester
I have 3 nagging issues at the moment:
1. Last year we had the engine re-conditioned. All is well, pulls a bit stronger, smooth as anything. But I see puffs of dark smoke puffing out when demanding revs in lower gears even when engine warmed up after more than 30 mins or so. Is this to be expected of a 20 odd year old engine, although in a sense it is 'new'?
2. Water, battery etc warning lights (zigger unit?) under sink has stopped working. No flicker.
3. Eberspracher heater unit works perfectly but will not switch off! I disable it by disconnecting wire under the seat.
Any thoughts on these issues gratefully received. Thanks for reading.
Paul
PS - would it be advisable to post these items as separate posts?
New on here.
Paul
