G
Gareth Salton
Hi.
Does anyone have any experience or knowledge regarding the factory for reversing camera fitted to the 2024 GC600…?
I have fitted a ladder, bike rack and some boxes to the back doors and as such they obscure the view of the existing camera. My plan is to build a 50cm extension arm that I can fit to the top of the brake light and rewire the camera on the end of the brake. I would also like to fit some beef up reversing lights after backing into a ditch on Christmas Eve on the Isle of Aaran and having to get a farmer tow me out
Everything you can find on the web refers to retrofit cameras that look like the GC 600 camera, but I’m guessing don’t have the same wiring.
So the question.
1. Where can I get a replacement camera that will simply plug and play directly into the existing wire loom?
2. Where can I source an extension cable that I can use to extend the existing loom by 50 cm?
3. How can I pick up a 12 V supply at the brake light that only comes on when the reversing camera is activated?
I’m sure I could solve a lot of these problems by myself if I could only find a wiring diagram for the factory fit camera and a pin out for the plug. If anyone has one of these that would be brilliant to see.
Hope you can help.
So the question.
Hope you can help.
