L
lohr500
Only used a couple of times when we used to go camping with a tent.
And then only for No.1's!!
Spotlessly clean and with the original box. The instructions are printed on the side of the box.
Very slight scuff mark on the lid, which is barely visible.
39.2cm tall, 36cm wide, 43.5cm tall.
15l tank for clean rinsing water.
20l tank for waste.
Detaches into two halves, with a sliding valve to seal the waste tank after use or for when taking the waste tank to an emptying point.
This potti is too large to fit under the sink or underneath the rear bed support board in the back of a T6.1 Ocean.
But it will sit on top of the bed board, or in between the front and rear seats for transportation.
Being slightly taller and having a larger capacity than the Porta Potti 335, it is easier to aim at/sit on .
And it has double the waste capacity so less frequent visits to those lovely chemical toilet emptying stations!
Cost new around £80 to £90.
Selling for £50. Collection only, near Skipton, North Yorkshire.
Thanks for looking.
20l tank for waste.
Thanks for looking.
