Fix for very slow drain from waste tank
andywa119
The drain from our waste tank was very slow. A drip, drip from the waste outlet. Sink would smell. Tried hot water down the sink and a plunger without success. To fix I directed a water hose up the waste outlet. Nothing at first, but the pressure then cleared the blockage and I could hear water flooding into the waste tank. Removed the hose and a few gallons of very smelly water came pouring out. Now emptying fine. :)
Good tip Andy mine is a little slow I will give it a try :thumb
Also remove and clean where the hose from sink bottom meets the top of the waste tank....as you will get a build up of grime there.....
