Fresh water tank replacement
jaikens
Canada
T4 PopTop
Bought a 1992 Westfalia Eurovan CV but missing the fresh water tank, pump and level sensor. I have searched this forum and many others but do not seem to find new T4 replacement tanks for sale. I would like the original Westy T4 tank that fits over the wheel well...any help is much appreciated.
Probably not something you’ll find easily to buy new. You could try a VW dealership to check availability of new parts but you’re more likely to find what you need at a specialist breakers yard.
The 1992 Westy would of had its water tank ion the right hand side of the boot (trunk) rather than in the bottom of the wardrobe which. This diagram should get you started with the part hunting - http://www.oemepc.com/vw/part_singl...070/subcategory/350000/part_id/3706723/lang/e
I see from your profile you're in Canada. If you don't find a solution on your side of the Atlantic, search these forums for 'breaker', you should find links to specialists over here. You're likely to have better chances in Germany or the Netherlands as a high concentration of old Cali's in those countries.
Personally I've found parts on the following second hand selling sites:
Good luck!
I am located in New Brunswick on the East coast of Canada and have not had much luck in Canada or US finding a tank. Shipping a tank from Europe might not be worth the cost. I am starting to think that I should just add a small 20 L tank and pump under the sink and wire to the existing faucet switch. Thank you for sites as these are a great resource for many parts.
