sidepod
- Messages
- 6,320
- Vehicle
- T4 PopTop
Chaps,
Odd fridge stuff going on.
Compressor is running. Heat exchanger plate inside the fridge is icing up.
I can adjust the amount of icing ( temp control) via the control panel and still the fridge space isn't cold. Thermometer on top of the butter says 17 degrees.
I've pulled apart all of the connectors and checked the Danfoss control unit connections.
All appears ok.
The fan next to the compressor is running ok.
Ambient temp is around 27 deg so this shouldn't be a problem.
The thermostat isn't switching off so the compressor runs continually but I guess this is something to do with the internal temp not coming down.
The only thing I can think of is the door seal is not working but the lid seems to shut ok?
V annoying.
Any thoughts?
S.
All appears ok.
V annoying.
Any thoughts?
S.
