viking
On our Cali it appeared that this support arm was too strong/ stiff. In closing the fridge lid it moved slightly sideways eventually pushing off the sirclips (split retaining washers) I eventually bought a set of new struts with fixings and clips only to find that the new strut was as stiff as my old one. The movement is worse where it fits at the plastic side of the fridge lid. The triangular bracket wobbles even after tightening up as much as I dare do. Does anyone know what the small bolts screw into on the other side of the plastic lid or are they just self tappers into the plastic. I'm reluctant to undo this bracket in case some retaining nuts fall off inside the fridge lid. Has anybody ventured behind the plastic and below the glass lid and seen this bracket fixing ?
