F
Fiona Hewitson
- Messages
- 2
Planning to change from a T6 Ocean to a nearly new California Grand 600 . Has anyone any experience of having the rear fitted aircon removed and replaced with a standard skylight and blind ?
Not heard of anyone doing this but be aware the aircon unit requires a smaller hole in the roof than the standard sky light that would otherwise be fitted, so you’d have to have the hole made bigger upon removing the aircon unit. Good luck!Planning to change from a T6 Ocean to a nearly new California Grand 600 . Has anyone any experience of having the rear fitted aircon removed and replaced with a standard skylight and blind ?
Ok that’s very helpful and provides a simple answer - leave well aloneNot heard of anyone doing this but be aware the aircon unit requires a smaller hole in the roof than the standard sky light that would otherwise be fitted, so you’d have to have the hole made bigger upon removing the aircon unit. Good luck!
