Amarillo
Tom
I’ve just loaded four bikes - 2 adult and 2 children’s - onto our Quasi bike rack. It took 6 minutes 5 seconds. I think that’s pretty good.
Nice job Tom , but then again you are a frequent user...
Out of curiosity , how old is your Cali and milage ?
Guess it was one of the early T6's
didn’t time it but under 10 mins for sure. Having 3 little sprogs doesn’t afford you any more time.
the fiddliest bit for me is positioning with pedal placement and chocks under wheels (you can’t leave them in place when pushed up so have to redo each time).
Good morning,
We using the bike rack not very often. Maybe I am to short for it, to lift the bikes up and fix it is a bit of a pain for me. I would have prefered the rack sitting on the tow bar (but that ship sailed, because to get this installed and a new bike rack would be to expensive).
Have I said all this, may I ask a question (while we talk about bike racks )? My wife loves cycling and we decided to get 2x electric folding bikes. I know they are folding bikes, but I still want to put them on the bike rack.
My question now is, has somebody put folding bikes on the bike rack? Normal frame size is different and I haven't thought it through if they actually can be nicely secured on the VW bike rack.
Happy California,
Eberhrad
What happens when you forget to put something in the boot...?
All off, start again
The lower the weight (higher weight, but lower to the ground!), the more stable.I wonder what difference the Towbar or tailgate racks make to the Centre of Gravity of the California, when fully loaded with bicycles?
At least half a bike height.Good question.
Both are behind the rear axel so will transfer weight from the front axel to the rear axel. The higher rack by marginally less than the lower one.
I think...
Not so much the forward or backward movement of the C of G but its height above road level.Good question.
I think...
But the question is: how long does it take you to bleed?If I do it without bleeding I usually see that as a success.
Surely those old traditions like discus and javelin can be dropped (pun intended)
