Hi if I charge the starter battery with a trickle charge will this also charge the leisure battery?
If not how are people charging the leisure battery at home?
Just replacing both leisure batteries. Question: Should I put them in now baring in mind the camper side of the van won't be used until next spring?....Or Keep old ones in, and put the new ones in then?
I would top up the charge on both of them and then install them. They also run the coil and fan for the parking heater, which could come in handy in winter even if you're not camping
