Van Maurice
We have the 255 18” wheels. Do Cali owners use level wedges generally and are there any wide enough for these wheels?
Thanks Billywizz. We’ll look them up...Hi the Fiamma level up chocks will be fine, just campers sell them they take up to 300mm wide tires
Thanks. Had a good read and it seems the owners are split between the ramps being needed and not needed at all...There are loads of posts regarding levelling, search "levelling ramps" ... Plenty to read! Good luck.
I did the same, agree you can get away without them, but they do give you the flexibility of being able to use any pitch.Thanks. Had a good read and it seems the owners are split between the ramps being needed and not needed at all...
We’ll go out and about first and see how we get on...
Main campsites shouldn’t be a problem in the U.K. Certified Locations run by the 2 main clubs can be more variable. On the continent similar for main sites but some of the ones we visit in forests or close to beaches are rarely very level, especially on the pitches we like.Thanks. Had a good read and it seems the owners are split between the ramps being needed and not needed at all...
