thanks glue it is thenHad similar issue here, but on the table. Eventually used epoxy glue in the bottom of the u section, or the edge of the panel with the trim kept in place until epoxy set by a couple of very tight ratchet straps overnight. (Clean excess epoxy immediately)
You could also try some paper wedged in the channel which kept it in place, but only for a couple of weeks.
I've found the ' Thick " Superglue very useful on vertical surfaces. Sticks quickly and just need a few spots rather than the whole length of detached trip.tha
thanks ordered from link- also have the epoxy version gorilla do on order as wellI've found the ' Thick " Superglue very useful on vertical surfaces. Sticks quickly and just need a few spots rather than the whole length of detached trip.
https://www.ebay.co.uk/itm/1-x-GORI...h=item5919802ba8:g:4FEAAOSwP8dcGVoQ:rk:9:pf:0
