Mysterious cable in driver's door found after removing door card
JohnnyRainbowDeer
JohnnyRainbowDeer
Praha
T5 Cali on order
I am in process of replacing a blown up speaker on my T5 California 2007. After removing door card I found a remnants of a cable which purpose is mysterious to me. Anybody knows what is the purpose of it and where it should be placed?
Given it's going to chassis it's an earth cable off something.
Off topic: I wouldn't advertise my VIN number to the whole world.
So I believe this is the heater remote Antenna, the plastic bracket is a bit bent, but it is meant to sit above the door and below the glass line. The exposed wire is the Antenna, it is a screened cable (Inner core with metal outer (coax) like a TV aerial cable. The metal outer is connected to the earth stud right next to the cable end. I would just carefully place it back with some strong tape, re bend bracket, you can see where the foam tape used to hold it in position
Thanks, It totally makes a sense. But what is the purpose of the heater remote antenna? It is a heat sensor? Or antenna for some wireless remote control? Cheers.
We have a separate remote control for the interior van heater and you can trigger it from a reasonable distance to pre heat the van.
I reckon that will be it. Might be useful to keep it there just in case. Thanks.
