N
Nejc
is that one of your own pictures on the table or one off the pixel website?When I bought mine 2nd hand someone had fitted a vinyl top that matched the original colour. Is it 2nd hand? If so check that. If under warranty you know what to do. To repair you could sand it down and fit your own vinyl to it. Here's mine.
pixeris that one of your own pictures on the table or one off the pixel website?
Love that table!When I bought mine 2nd hand someone had fitted a vinyl top that matched the original colour. Is it 2nd hand? If so check that. If under warranty you know what to do. To repair you could sand it down and fit your own vinyl to it. Here's mine.
No it is not 2nd hand. Original. However many thanks for your reply. Btw where have you bought the vinyl and I think you have to remove the Aluminium edge protector first not to damage it when sand it down?When I bought mine 2nd hand someone had fitted a vinyl top that matched the original colour. Is it 2nd hand? If so check that. If under warranty you know what to do. To repair you could sand it down and fit your own vinyl to it. Here's mine.
On the table, I noticed small bumps on the surface. Is it possible that the table is not resistant to moisture (rain) and the surface itself has been damaged as a result? It looks like moisture has inflated the base plate.
Shouldn't think so. It's only thin sticky-backed material. There are no claims to heat resistance.Can you put hot plates directly on the pixer cover ?
Did you fit anything to the bottom of the legs after shortening them? And what did you cut them with? I'd quite like to do this too!We found the height of the table was very uncomfortable to sit and eat at. So l cut a bit off the bottom of the legs to reduce the height. Made it much better.
Thanks for the answers. However, it is strange that a relatively expensive vehicle is fitted with components that are not moisture-resistant when designed for outdoor use.We found this on our previous van - slightly raised ridges across the table surface. We'd never left it out in the rain, but had often left it under the awning but in the damp, overnight. Will be more careful with the new van's table (once we get a chance to take it anywhere!).
