LucyYorkshire
Bought for £450 a few months ago. Used for 5 nights in total.
Will accept £310. Collection from just outside Bradford - BD18.Fabulous awning - we’re streamlining our van and as we do mainly single nights away we don’t really need this. Would be fantastic for 2 plus nights and soooo easy to put up.
You can buy a separate groundsheet and carpet but we don’t have these.
Blurb from the Outwell: Spacious and versatile, with flexible van connection options, the Outwell Lakecrest campervan awning is pitched using partial pole sleeves and clips for its colour-coded frame. By rolling away the front panel completely and removing the groundsheet, it can be set up as a generously-sized canopy. Its front wall, with 2-way zipper and door, features a mesh panel and tinted window combo that complements the twin mesh side windows for ample light and ventilation. All are backed by zip-up curtains. Twin side doors in the large Link Access Zone, with draught skirt, ensure easy access to the van and rear wall.
Specifications- Type of tent: Drive-away campervan awning
- Flysheet: Outtex® 3000 Select, 100% polyester
- Hydrostatic Head: 3000 mm
- Roof connection length: 240 cm
- Attachment height: 175 - 200 cm
- Bead thickness: 7 mm / 5 mm
- Poles: Aluminium #6061, T6, 14.5 mm, anodised
- Groundsheet: Double-coated waterproof polyethylene, 100% polyethylene
- Pack size: 62 x 31 x 31 cm
- Weight: 11.4 kg
- Awning Type: Drive-Away
- Item number: 111166
- Large side mesh windows with waterproof curtains enhance ventilation
- Large tinted front window maintains privacy and views while reducing the sun's glare
- Large rear opening for easy use of the Link Access Zone
- Roll away front door enhances Panorama view, access and ventilation
- Heavy duty Outwell zips for enhanced performance
- Detachable bathtub groundsheet cuts out draughts, water ingress and crawling insects
- Removeable bathtup style groundsheet
- Pre-attached luminous guylines for convenience and fast pitching
- HookTrack System for versatile positioning of lights and items up to 1.5kg
- Groundsheet for Link Access Zone with built-in draught excluder skirt
- Fast and easy to attach and detach
