Haves1979
How accurate is the overhead control panel volt meter and do you need to do anything to reset it? Currently it is showing 12.4v, however my Victron Smartsolar app is showing 13.69v and on float?
The Control Panel voltmeter is accurate.How accurate is the overhead control panel volt meter and do you need to do anything to reset it? Currently it is showing 12.4v, however my Victron Smartsolar app is showing 13.69v and on float?
There is a very high probability that the Cube fuse on the +tve pole of the rear Leisure Battery has failed. This fuse, originally 50amp since upgraded to 75amp, connects the 2 Leisure Batteries together.Its a T5.1 SE, with a victron controller straight the batteries using an app.
Please let the Forum know the outcome.Thanks I'll check this when we get home.
Cheers
I would say, either your solar charger voltmeter is very inaccurate, or you have some corroded or undersized wiring between the charger and battery and the voltage is dropping across that.To follow up on this, the cube fuse was OK, or at least it looked OK. I have replaced anyway just in case.
Now we are getting some warmer/sunnier weather I'm seeing much better voltages. The batteries are definely both linked the rear battery voltage drops when in use.
What I'm seeing is that my volt meter matches the vw display exactly. However, the solar app, shows about 0.3-0.4v too high. Not sure of the cause but it is definitely charging the battery so a minor issue really.
Thanks for the pointers.
All the solar kit is the standard stuff from solar camper solutions. Charger is a Victron, which I believe are decent.I would say, either your solar charger voltmeter is very inaccurate, or you have some corroded or undersized wiring between the charger and battery and the voltage is dropping across that.
Have you used your multimeter at rear battery, black probe to chassis or -ve battery terminal. Red probe first to top of cube fuse, second to bottom of cube fuse. Do readings exactly match ?All the solar kit is the standard stuff from solar camper solutions. Charger is a Victron, which I believe are decent.
And is it that reading that's the same both sides that matches the control panel ? If so the. I would try to measure the voltage at the output of the charge controller. You really need to find out if it's an inaccurate controller or voltage drop in the charging wiring, if it's drop in wiring then it could potentially get hot and cause you a problem. If it's inaccuracy in the control voltage reading then less of a problem, but it does mean it probably won't fully charge your battery because if it's over reading it will think it's full before it isI did indeed, same reading at both points.
As above. I have exactly the same voltage reading on my Control Panel when the sun is up as I do on my Solar Panel Controller. They mimic each other.I did indeed, same reading at both points.
