caligraphy
- Messages
- 90
My T5 has started doing a strange thing. It was absolutely fine than I just got it back from a service and it started running hotter than normal. The temp gauge is saying it's exceeding the normal 90degC for the first time ever. This happens when running hard uphill but its never done it before. There is no excess pressure in the coolant. Curiously it doesn't seem especially hot. I can open the expansion tank within 10 minutes with no bubbling or scalding. Just a little hiss.
My engine is the 174 2.5 TDi. I've heard talk of water pump impellers and head gaskets but not on these. These engines are reputedly bullet proof (I suspect VW only changed them to reduce the range they carried and meet Euro 5/6 requirements). Besides, the engine seems healthy. No faullt was found in the service. It has low miles and fuel economy varies from 40 MPG mixed cycle to 47 MPG highway cruising on average (6-7l/100km).
I'll take it back tomorrow to the place I had it serviced. I am concerned that they've slightly overfilled the oil from what I can see. I'll also need to check the coolant level when it's cold.
Has anyone seen a similar problem, especially happening suddenly after servicing `/
