Morganic
- Messages
- 164
- Vehicle
- T5 SE 180
Had the picnic table that’s mounted in the door out today. When I tried to put it back in it wouldn’t clip back in place. Any suggestions please?
I suspectHad the picnic table that’s mounted in the door out today. When I tried to put it back in it wouldn’t clip back in place. Any suggestions please?
Many thanks. I’ve looked into the aperture and I can see something shiny. The handle seems as if it’s unconnected and is loose Is this because the latch has become detached. Thanks for your helpIf the latch is down you need to push the table in firmly at the top to make it click. If the latch is stuck in the up position you need to push it back down while holding the table in at the top . As said make sure the table is sat proper at the bottom
I have to actively lift the latch, place the table in slot, push table in at the top and push latch down again.Many thanks. I’ve looked into the aperture and I can see something shiny. The handle seems as if it’s unconnected and is loose Is this because the latch has become detached. Thanks for your help
Thanks I’ll give it a go!I have to actively lift the latch, place the table in slot, push table in at the top and push latch down again.
Thanks everyone. It worked. Pushed the table into the bottom of the door, pushed the top into the aperture and pushed the latch down hard. It worked a treatI have to actively lift the latch, place the table in slot, push table in at the top and push latch down again.
Brute force! I've had the problem for 12 years - you literally have to bash it into place.Had the picnic table that’s mounted in the door out today. When I tried to put it back in it wouldn’t clip back in place. Any suggestions please?
Thanks. I found that latch stayed up and you had to press it back down hard. It doesn’t rattle but the table does!While at that, also wrap some electrical tape around the catch below the table. Stops it from rattling against the latch on the door.
