Pop top issues
Vic
Vic
Dorset
Just browsing
Hi everyone im recently having some issues with our pop top on our Cali it goes up lovely and comes down lovely but when down and the motor Has stop as we pull away it starts to ping and say its open But is obviously all the way down I am stumped as their is nothing around the roof seal stopping it anyone else had this issue or can point me in the right direction to getting it fixed Or the right thread cheers.
Not knowing which vehicle you have makes it difficult, I’m afraid. According to your Avatar details you’re still looking.
Sorry he's a 2012 California berghaus
Try this.
For those of you who don't know, if you ever get any problems with roof stuck or any other error say with the heater or fridge, you are able to access the hidden menu in your control panel as used by the VW Engineers.
Access as follows:
1. Hold down the centre of the rotary button together with the menu button (button below with the squares on it)
2. You will get the hidden menu.
3. Rotate the rotary button to get to "VW diagnose" and select this by pressing on the centre of the rotary button.
4. If no errors are present it will display "no errors"
5. If Errors are present then a list of errors will appear
6. Press the centre of the rotary button again to delete all the errors
7. Repeat process above just to check that errors have dissapeared!
8. Re-configure the time and date if neccesary.
Any problems should be resolved assuming these are Electronic and not Mechanical.
Error Codes from Control Panel.
1 = 1 = Pop-up roof
2 = 2 = Plumbing Heating
3 = 3 = Cool box Cooler
4 = 4 = Sewage wastewater
5 = 5 = Fresh water
6 = 6 = Outside temperature
7 = 7 = Battery
Error Code Defect Fault
1010 1010 Short-circuit to (earth) roof
1001 1001 Fuse / short circuit to (plus+) roof
1100 1100 Short-circuit output Roof "on"
1101 1101 Fuse roof "to"
1110 1110 Short-circuit output Roof "to"
1111 1111 Fuse starting Roof "to"
2100 2100 Short-circuit output heating on / off
2101 2101 Fuse output heating on / off
2001 2001 Interrupt input heating 30
3100 3100 Short-circuit output coolbox
3101 3101 Fuse interrupt output coolbox
3001 3001-J698-cooler input error "Active"
3010 3010 Short-circuit input icebox "actual temperature"
3011 3011 Interrupt or fuse input icebox "actual temperature"
4000 4000 Short-circuit to ground water level sensor
4001 4001 Fuse circuit to plus water level sensor failure
5000 5000 Short-circuit to ground water level sensor
5001 5001 Short circuit to plus water level sensor failure
6000 6000 Short-circuit to ground temperature sensor or for outdoor temperature
6001 6001 Fuse / short circuit to plus two temperature sensors for outside temperature
7001 7001 interrupt input interrupt input D +
So which is the menu botton on this panel as their are no bottons with a squares on it?
As as far as I'm aware it's the centre button that you are telling me to hold down which access our menu so what other botton do I need to hold ?
So hold the centre of the dial botton along with the return arrow will get me the menu
Hold in the centre button and at the same time the one with the return arrow.
  • Like
Reactions: Vic
Ok so I have 1 code 1000 that's not on the list and pressing the centre button isn't deleting it and the message tells me how but don't know what to do to delete it
Okay, if you can remove the control panel - either that or disconnect the
starter battery for 5 or 10mins. That should reset it.
Once you've done that then pop your roof up and down a couple of times, you
might be lucky and all your problems have gone.
@TripleBee might know a bit too.
I did that but it jumps back to the vw diagnostics menu and it doesn't get rid of it
That means it is a Permanent fault rather than a temporary fault. Probably one of the 4 sensors has failed so the Computer thinks the roof is not closed correctly.
The sensor needs to be replaced, but it is integral with the wiring loom for the roof.
Or you have a permanent fault on one of the sensors on the hydraulic rams.
I had 2 wires disconnected from the sensors on the right ram, and I had a warning on the display too to put on the ignition to operate the roof, while the ignition was on.
Repaired the wires, no faults anymore. Worth to check.
Where on the rams is the wiring as when up I can't see any wires ?
Before attacking where the wires are have you
disconnected the power?
Just disconnect the main ignition battery not any of the leisure batteries
With the roof popped if I disconnect the power to check the wire in the arms will the roof stay up ?
Post #14 is what i am on about,
if you want to check the ram wiring then of course the
roof must be up.
6K
BeeBee
Anthony1
Elly Swanson
Elly Swanson
couplands
Andy C Berks.
Andy C Berks.
