Puddle Lights
Details of the fitting?
Not too bad a job.
Got a kit off a guy on T6 Forum.
I think the puddle lights are off a Passat and he supplies full instructions, a loom with a relay and fuse.
Door card off obviously and cut out the holes with a new Stanley blade.
3 wires to connect, perm 12v from the window motor, switched 12v from the door handle and chassis ground.
Only issue I had is the handle wiring is different between the t6 and t6.1 but not a huge problem if you have a multimeter.
Not too bad a job.
Looks good. Nice feature.
