Replacing leisure batteries
piddi
piddi
Norway
T5 SE 130
Another stupid question probably (sorry folks).
Replacing the leisure batteries, can I just pick any 12V 75Ah batteries?
What do the 420a and 800A on the original batteries mean?
Thanks!
I am not 100% sure but I think that relates to amount of power the battery can supply if it is used to start an engine. It is not really relevant when using it as a leisure battery. That said, a leisure battery is designed for deep charge and discharge cycles and not for regular short burst of power as when starting a vehicle.
The Leisure Battery compartments are also designed for certain sized batteries with the terminals in a certain orientation which will limit your choice..
What ever you do, don't put "engine cranking" batteries as a replacement for the leisure batteries, they are a different type of battery.
