aileron346
- Messages
- 237
- Location
- North Yorkshire
I'd be grateful for any advice about retrofitting towbars the the facelifted 2010--> Calis. The two main options seem to be:
1) a full fitting with dedicated wiring loom going through to the engine.. OR..
2) The towbar electrics simply wired into the rear lighting systems.
It seems that 1) involves a fair bit of work and so expense. For the 2nd option, I realise that obviously it cannot function with the ESP. Is there also a problem with the reversing sensors? Or is that all OK if a detachable towbar is fitted?
Is 2) generally considered an 'OK' option for retrofitting a towbar to the Cali for occasional trailer towing but more frequent bike carrier use?
Thanks for any advice/comments/opinions.
Cheers
Paul
Cheers
Paul
